etc77f5nr
Szia! Megnéztem a kódot, de valamit rosszul másoltál ki, mert mach3 hibát ír  9. sorra.
kua93zk4w
Ezek csak kökök de a hiba itt is megvan
(próba körök)
G90
G21
G49
G0Z15.0000
M3 S1000
G0 X-27.0000 Y0.0000 Z5.0000
G1   Z-1.0000 F1000
G2 X-20.0172 Y18.1189 I26.9639 J0.0134 F2000
G2 X0.0253 Y26.9998 I19.9980 J-18.0751
G2 X18.1189 Y20.0172 I0.0013 J-26.9302
G2 X26.9998 Y-0.0253 I-18.0751 J-19.9980
G2 X20.0172 Y-18.1189 I-26.9302 J-0.0013
G2 X-0.0253 Y-26.9998 I-19.9980 J18.0751
G2 X-9.3066 Y-25.3525 I-0.0015 J26.9602
G2 X-27.0000 Y0.0000 I9.3246 J25.3579
G0   Z5.0000
G0 X-152.0000
G1   Z-1.0000 F1000
G2 X-145.7141 Y43.3978 I152.2711 J0.0985 F2000
G2 X-102.2106 Y112.5047 I145.6772 J-43.4588
G2 X-11.7054 Y151.5559 I102.0103 J-112.0164
G2 X43.3978 Y145.7141 I11.7227 J-152.2285
G2 X112.5047 Y102.2106 I-43.4588 J-145.6772
G2 X151.6908 Y9.7724 I-112.0236 J-102.0136
G2 X145.1697 Y-45.1876 I-152.2167 J-9.8060
G2 X99.4823 Y-114.9260 I-145.2030 J45.2914
G2 X3.9349 Y-151.9500 I-99.2951 J114.4485
G2 X-55.7234 Y-141.4605 I-4.0532 J151.8441
G2 X-129.9869 Y-78.8293 I56.0350 J141.7858
G2 X-152.0000 Y0.0000 I129.5196 J78.6566
G0   Z5.0000
G0 X-150.0000
G1   Z-1.0000 F1000
G2 X-116.8854 Y94.0179 I149.5286 J0.1744 F2000
G2 X-48.1094 Y142.1187 I117.0612 J-94.1584
G2 X7.7190 Y149.8048 I48.0508 J-142.4199
G2 X100.8566 Y111.0327 I-7.5270 J-149.3341
G2 X143.7936 Y42.8394 I-100.8201 J-111.0940
G2 X149.5626 Y-11.5411 I-144.4653 J-42.8221
G2 X111.0327 Y-100.8566 I-149.0742 J11.3407
G2 X42.8394 Y-143.7936 I-111.0940 J100.8201
G2 X-11.5411 Y-149.5626 I-42.8221 J144.4653
G2 X-100.8566 Y-111.0327 I11.3407 J149.0742
G2 X-143.7936 Y-42.8394 I100.8201 J111.0940
G2 X-150.0000 Y0.0000 I143.8812 J42.7143
G0   Z5.0000
G0 X-103.8899 Y-93.9279
G1   Z-1.0000 F1000
G1 X83.9658 Y89.6584  F2000
G0   Z5.0000
G0 X0.0000 Y0.0000 Z15.0000
G0Z15.0000
G0X0.0000Y0.0000
M5
M30
kua93zk4w
Bocs kökök= körök
etc77f5nr
Ennél a 20.sorban ír hibát a Mach3.. "Radius to end of arc differs from radius to startline 20"
etc77f5nr
Nézd meg ezt, bár gondolom ugyanaz lesz a helyzet.
G0 G49 G40  G17 G80 G50 G90
M6 T0(TOOL DIA.12)
G64
G21 (mm)
M04 S0
G00 G43 H0  Z3
X100 Y100
G01 Z-1 F150
G2 Y100 X112 R6 F2000
Y100 X88 R12
Y100 X124 R18
Y100 X76 R24
Y100 X136 R30
Y100 X64 R36
Y100 X148 R42
Y100 X52 R48
Y100 X160 R54
Y100 X40 R60
Y100 X172 R66
Y100 X28 R72
Y100 X184 R78
Y100 X16 R84
Y100 X194 R89
Y100 X6 R94
X194 Y100 R94
Y90 X184 R10
G00 Z3
M5 M9
M30
kua93zk4w
Elmentettem txt be úgy is végig ment.
Elküldöm mailbe.
A Robsy csillag teszttel (#12868)nézd meg, hátha kiderül valami, és azt pl. nem akadozva hajtva végre. Vagy ha lassan megunod ezt a sok bosszantó időrabló jelenséget, térj át más stabil működésű vezérlő progira.
Az a főorsó felpörgetése.
A program megvárja amíg felpörög a főorsó, tehát ha valami visszacsatolást bekapcsoltál hogy figyelje a fordulatot, de mivel feltételezem nincs ilyen visszajelzés neked, ezért soha nem éri el az üzemi fordulatot, így nem is indul el a program.
Az lehet tényleg, utánanézek. Kösz.
Azt inkább a szakadozó üzemre írtam.
Az hogy megáll az sok mindentől lehet. Ha kilép a soft limitekből a koordináta, vagy várakozásra kényszeríti elektron problémájához hasonlóan valami. Esetleg MACH3 program hiba, vagy a demoverzió korlátozása maradt benne, de az ha jól tudom az 500-adik sorál állítja le.
Esetleg a gkód előre olvasást vedd kisebbre, bár aligha telik meg egy normál gép memóriáj ezzel.
Kezdőként kérdezem:
Annak mi lehet az oka, hogy lenullázok minden tengelyt egy adott koordinátán, majd billentyűvel elviszem a főorsót mondjuk kb. 150mm-ert az Xtenglyen, majd vissza viszem abba a pozicióba ahol nulláztam, és nem közel nullát ír pozicíóra, hanem kb. -40mm-ert. Természetes hogy nem pontos, legalábbis szerintem, mert szemre állítom vissza, de azért 40mm-ert nem kellene hibáznia. Én gondolok valamit rosszul, vagy ez valami gépi tulajdonság lehet?
Üdv:
Fidomaster
etc77f5nr
Rosszul van megadva a step/per és a valóságban nem annyit léptet, mint amennyit mozdul.
etc77f5nr
Bár ha kézzel mész el 150-et akkor kézzel kb ugyanoda visszaállva -40 akkor az érdekesebb dolog lesz. Nem téveszt lépést?
Őszintén megmondom, nem tudom.
Egy próba marást végeztem vele eddig, egy hópelyhet rajzoltam, és generáltattam a G-kódot. azt hiba nélkül megoldotta, méret pontosan.
Szerettem volna végálláskapcsolokkal megoldani a referencia pontot, de ezek után nem tudom hogy azzal nem lesz e gond :(
kua93zk4w
Hát a robsy teszt nem végződött valami jój úgy rákódott a gép mintha vacogna.
Van valami könnyen elérhető program amihez nem kell új vezérlőt építeni?
