Kelepeisz Lajos
Mindjárt meglesem.
Közbe csináltam egy tesztet direktbe kapcsolt lézerrel, ezzel a résszel nincs gond.
Kelepeisz Lajos
Kelepeisz Lajos
Itt a teljes tartalom, amit átírtam elektron ajánlása szerint, de továbbra is hibára fut.
// Options for pcb-gcode.ulp.
// Often used options are at the top of the file.
// Copied to gcode-defaults.h by the setup program.
// author=John Johnson
// description=Mach3 - EMC for Windows
int FILENAMES_8_CHARACTERS = NO;
// Comments.
string COMMENT_BEGIN = "(";
string COMMENT_END   = ")";
// Format strings for coordinates, etc.
string EOL        = "\n";                   /* standard line ending */
string PARAM      = "P";                    /* some use P, some # for parameters */
string FORMAT     = "%-7.4f ";        /* coordinate format */
string FR_FORMAT  = "F%-5.0f ";      /* feedrate format */
string IJ_FORMAT  = "I" + FORMAT + "J" + FORMAT;
// Modes
string INCH_MODE            = "G20" + EOL;
string INCH_MODE_COMMENT    = COMMENT_BEGIN + "Inch Mode" + COMMENT_END + EOL;
string METRIC_MODE          = "G21" + EOL;
string METRIC_MODE_COMMENT  = COMMENT_BEGIN + "Metric Mode" + COMMENT_END + EOL;
string MIL_MODE             = "M02 (Please setup MIL_MODE in gcode-defaults.h)" + EOL;
string MICRON_MODE          = "M02 (Please setup MICRON_MODE in gcode-defaults.h)" + EOL;
string ABSOLUTE_MODE        = COMMENT_BEGIN + "Absolute Coordinates" + COMMENT_END + EOL + "G90" + EOL;
// G codes
string RAPID   = "M11"+EOL+"G00"
string FEED    = "M10"+EOL+"G01"
string ARC_CW  = "G02 ";
string ARC_CCW = "G03 ";
string DWELL   = "G04 " + PARAM + "%f" + EOL;
// M codes
string SPINDLE_ON  = "M03" + EOL + DWELL;
string SPINDLE_OFF = "M05" + EOL;
string END_PROGRAM    = "M02" + EOL;
string OPERATOR_PAUSE = "M06 ";
// Coordinates
string MOVE_X   = "X" + FORMAT;
string MOVE_Y   = "Y" + FORMAT;
string MOVE_XY  = "X" + FORMAT + "Y" + FORMAT;
string MOVE_Z   = "Z" + FORMAT;
string MOVE_XYZ = MOVE_XY + MOVE_Z;
// Rapids
string RAPID_MOVE_X       = RAPID + MOVE_X;
string RAPID_MOVE_Y       = RAPID + MOVE_Y;
string RAPID_MOVE_XY      = RAPID + MOVE_XY;
string RAPID_MOVE_XY_HOME = RAPID + "X0 Y0";
string RAPID_MOVE_Z       = RAPID + MOVE_Z;
string RAPID_MOVE_XYZ     = RAPID + MOVE_XYZ;
// Feeds
string FEED_MOVE_X            = FEED + MOVE_X;
string FEED_MOVE_Y            = FEED + MOVE_Y;
string FEED_MOVE_XY           = FEED + MOVE_XY;
string FEED_MOVE_XY_WITH_RATE = FEED + MOVE_XY + FR_FORMAT;
string FEED_MOVE_Z            = FEED + MOVE_Z;
string FEED_MOVE_Z_WITH_RATE  = FEED + MOVE_Z   + FR_FORMAT;
string FEED_MOVE_XYZ          = FEED + MOVE_XYZ;
// Drilling holes
// G82 Xx.xxx Yy.yyy Z.zzz Fff.f Rr.rrr #dwell
string DRILL_CODE       = "G82 ";
string RELEASE_PLANE    = "R" + FORMAT;
string DWELL_TIME       = PARAM + "%f";
string DRILL_FIRST_HOLE = DRILL_CODE + MOVE_XYZ + FR_FORMAT + RELEASE_PLANE + DWELL_TIME + EOL;
string DRILL_HOLE       = DRILL_CODE + MOVE_XY + EOL;
// Tool change
string TOOL_CODE        = "T%02d ";
string TOOL_MM_FORMAT   = "%1.3fmm";
string TOOL_INCH_FORMAT = "%1.4fin";
string TOOL_CHANGE      = OPERATOR_PAUSE + TOOL_CODE + " ; " + FORMAT + EOL;
string TOOL_CHANGE_TABLE_HEADER = COMMENT_BEGIN +
  " Tool|       Size       |  Min Sub |  Max Sub |   Count " + COMMENT_END + EOL;
string TOOL_CHANGE_TABLE_FORMAT(int tool_number, real size_mm, real size_inch, real min_drill, real max_drill, int count)
  string formatted;
  sprintf(formatted, COMMENT_BEGIN + " " +
    TOOL_CODE + "| " + TOOL_MM_FORMAT + " " +
    TOOL_INCH_FORMAT + " | " + TOOL_INCH_FORMAT + " | " +
    "   %4d" + " " +
    COMMENT_END + EOL,
    tool_number, size_mm, size_inch, min_drill, max_drill, count);
  return(formatted);
// Circles / Arcs
string CIRCLE_TOP     = ARC_CW + MOVE_XY + IJ_FORMAT + EOL;
string CIRCLE_BOTTOM  = ARC_CCW + MOVE_XY + IJ_FORMAT + EOL;
kaqkk007
// M codes
Erről a részről beszéltem itt még mindíg az m03-05  kódok vannak
A sorok végén lemaradt a ";"  , az a baja.
Így javítva van.
// G codes
string RAPID   = "M11"+EOL+"G00";
string FEED    = "M10"+EOL+"G01";
Kelepeisz Lajos
Köszönöm elektron, működik hibátlanul, de sajnos a teszteken azt vettem észre hogy ez nagyon nem alkalmas lézerezésre, látszik is hogy nem arra készült.
[#rinya]
Kelepeisz Lajos
Hogy adsz a szigetelt részeknek vastagságot, a furatoknak hogy lesz átmérője, itt nem süllyed be egy V alakú kés, itt egy 0,1mm-es pont van?
Én már most konkrétan nem emlékszem ez a PCB-gcode meylik is, a menüjében be leeht ezeknek állítani minden paramétert elvileg, vagy van külön pcb-gcode setup.ulpje is pl, amit én még hazsnáltam a FastGcode.ulp azt hiszem az is elég jó volt.
Most meg kijártam egy olaan utat, hogy:
PDF nyáktervből:
- kiexportálni InkScape-pel 1200dpi-be PNG-be
- autotrace.org oldalon dxf-be a körvonalát kimenteni
- Cut2D -ben meg pocket-tel generálom az gcode-ot ott is csináltam egy laser-nek direkt egy setup filet.
Ez faszán megcsinálta most akarom kilézerezni a nyákot.
Kelepeisz Lajos
Majd légyszi egy képet a végeredményről.
Tulajdonképpen, hogy akarsz a lézerrel panelt gyártani?
Mi az elképzelés?
Kelepeisz Lajos
De ahogy mondtam működik a program lézerrel csak egy kicsit nem kerek ez ez a szigetelőréteg szélesség dolog, holnap rakok ki képeket.[#wave]
Kelepeisz Lajos
Sehogy, nem panelgyártás a célom, csak kipróbáltam hogy sikerül-e, mást akarok vele csinálni, amire szántam úgy érzem így már jó.
Kelepeisz Lajos
Annó te hogy csináltad amit csináltál, mintha képet gravíroznál, méretarányos volt?
