ArtCam & Relief marás
Próbáld ki ezt:
; Fanuc G - Code 4-Axis rotary post processor
; Linear Y Axis is wrapped onto A rotary axis
; History
; Who When        What
; MODIFIED FOR TRUE Y TO A ROTARY OUTPUT
DESCRIPTION = "Mach2 4-Axis Rotary Y->A mm(*.cnc)"
FILE_EXTENSION = "cnc"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START    = 0
LINE_NUM_INCREMENT = 1
LINE_NUM_MAXIMUM  = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.0]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|A|1.3]
FORMAT = [Z|#|Z|1.3]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|A|1.3]
FORMAT = [ZH|@|Z|1.3]
; Set up program header
START = "%"
START = "G90"
;START = "G21"
; G20 = Use MM as unit value
START = "G49"
;START = "M6 T1"
; M6T1 = tool change via macros (commented out)
START = "M3 "
;START = "M7"
; M7 = turn misting coolant on (commented out)
; Program moves
FIRST_RAPID_RATE_MOVE  = "G0
  • [Y] [Z]"
FIRST_FEED_RATE_MOVE  = "G1
  • [Y] [Z] [F]"
FEED_RATE_MOVE        = "
  • [Y] [Z]"
; End of file
END = "G0[ZH]"
END = "[XH][YH]"
END = "M05"
END = "M02"
END = "%"
azt hiszem még bekell állitani a Relief menüben - create rotary relief - wrap Y
Idézetet írta: Gepallat Dátum 2026 május 30, 20:05Hello, közben eljutottam idáig, letöltöttem , bemásoltam, ugyanúgy csak 3 tengelyre generál pályát.
Valami ötlet, nálam mit kéne még állítsak ha nálad jó ?
Gepallat
Idézetet írta: D.Laci Dátum Ma - 09:43Próbáld ki ezt:
; History
; Who When        What
UNITS = MM
; Block numbering
LINE_NUM_START    = 0
; Line numbering
; Spindle Speed
; Feed Rate
START = "%"
START = "G90"
;START = "G21"
START = "G49"
;START = "M6 T1"
START = "M3 "
;START = "M7"
; Program moves
  • [Y] [Z]"
  • [Y] [Z] [F]"
FEED_RATE_MOVE        = "
  • [Y] [Z]"
; End of file
END = "G0[ZH]"
END = "[XH][YH]"
END = "M05"
END = "M02"
END = "%"
Szia , ezzel is csak sima x,y,z G kódokat generál. Némelyik postprocessorral y-ból csinál A-t , de használhatatlan, pl 1-2 órás marás lenne fél napos , rengeteg fölös mellékmozgással. Sima indexmarás többet ér.
Az lenne jó ha amit leszimulál az artcam, szinte egy az egyben rágenerálná a mach3-ra. Helyette teljesen más pályát készít bármelyik 4 tengelyes postprocessor.
