Arduino
Arany János
Hogyan?
Mi kössek és hová?
Fogalmam sincs![#nemtudom]
state láb hc>> mega 9 láb!
ilyenkor indisd ujra egyszere tápfeszel mega hc05!
error 0 jön visza AT akor jó jel irt be mégegyszer AT..
de ezt is megkel csinálni...
BTserial.begin(9600);
ird át
 BTserial.begin(38400);
mega ujratölt!
//http://www.martyncurrey.com/bluetooth-modules/
#include <SoftwareSerial.h>
#define ledPin 9 // Connect the HC-05 STATE
SoftwareSerial BTserial(10, 11); // RX | TX
// Connect the HC-05 TX to Arduino pin 10 RX.
// Connect the HC-05 RX to Arduino pin 11 TX
char c = ' ';
void setup()
   pinMode(ledPin, OUTPUT);
   digitalWrite(ledPin, HIGH);
    Serial.begin(9600);
    Serial.println("HELLO AT");
     // HC-05 default serial speed for commincation mode is 9600
   // BTserial.begin(38400);
Serial.read(1);
void loop()
    // Keep reading from HC-05 and send to Arduino Serial Monitor
    if (BTserial.available())
        c = BTserial.read();
        Serial.write(c);
    // Keep reading from Arduino Serial Monitor and send to HC-05
    if (Serial.available())
        c =  Serial.read();
        BTserial.write(c);
bekötés
Arany János
Arduino: 1.8.4 (Windows 7), Alaplap:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\tata\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\tata\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\tata\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10804 -build-path C:\Users\tata\AppData\Local\Temp\arduino_build_439664 -warnings=default -build-cache C:\Users\tata\AppData\Local\Temp\arduino_cache_111216 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\tata\Documents\Arduino\sketch_v_lt_s3\sketch_v_lt_s3.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\tata\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\tata\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\tata\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10804 -build-path C:\Users\tata\AppData\Local\Temp\arduino_build_439664 -warnings=default -build-cache C:\Users\tata\AppData\Local\Temp\arduino_cache_111216 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\tata\Documents\Arduino\sketch_v_lt_s3\sketch_v_lt_s3.ino
Using board 'mega' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\tata\AppData\Local\Temp\arduino_build_439664\sketch\sketch_v_lt_s3.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\tata\AppData\Local\Temp\arduino_build_439664\sketch\sketch_v_lt_s3.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\tata\AppData\Local\Temp\arduino_build_439664\sketch\sketch_v_lt_s3.ino.cpp" -o "C:\Users\tata\AppData\Local\Temp\arduino_build_439664\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\tata\AppData\Local\Temp\arduino_build_439664\preproc\ctags_target_for_gcc_minus_e.cpp"
Vázlat fordítása...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os  -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\tata\AppData\Local\Temp\arduino_build_439664\sketch\sketch_v_lt_s3.ino.cpp" -o "C:\Users\tata\AppData\Local\Temp\arduino_build_439664\sketch\sketch_v_lt_s3.ino.cpp.o"
C:\Users\tata\Documents\Arduino\sketch_v_lt_s3\sketch_v_lt_s3.ino: In function 'void setup()':
sketch_v_lt_s3:25: error: no matching function for call to 'HardwareSerial::read(int)'
 Serial.read(1);
C:\Users\tata\Documents\Arduino\sketch_v_lt_s3\sketch_v_lt_s3.ino:25:14: note: candidate is:
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:232:0,
                 from C:\Users\tata\AppData\Local\Temp\arduino_build_439664\sketch\sketch_v_lt_s3.ino.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:126:17: note: virtual int HardwareSerial::read()
     virtual int read(void);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:126:17: note:   candidate expects 0 arguments, 1 provided
SoftwareSerial könyvtár használata a(z) 1.0 verzión ebben a mappában: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
exit status 1
van egy szemét a kodban bene marat töröld ki!
Serial.read(1);
Arany János
Továbbra is :"err"
kg0sy39yf
Vázlat fordítása...
 Serial.read(1);
exit status 1
Már lehet így is!
Egyszerűbb nem?
VViktor
Sziasztok. Csak nekem esett szét a fórum, a code beillesztéstől?
Arany János
Arany János
Ezt meg hogyan???
Egyébként lentebb már csináltam!
Az "err" a terminálban jön.
kg0sy39yf
Nem!
Nekem is!
Már írtam az illetékesnek!
Remélem nem csesztem szét![#idiota]
Arany János
Hát ez óriási lett!
kg0sy39yf
A " és " tag-ek közé írt/másolt sorok a hozzászólásban egy "dobozban" jelennek meg, melyet az alatta lévő gomb megnyomásával az eredeti formázással a vágólapra másolhatsz, ahonnan tetszőleges másik programba/helyre be tudod illeszteni.
